Adding and Removing Areas of Authority
You can change your areas of authority at any time. Select Authority from the Workspace Banner Tool Selector () drop‑down list (see “Understanding the Tool Selector” for more information on the Tool Selector selection options).
When the Authority dialog box opens, you can add subscription areas or unsubscribe.
• To add one or more areas, select the areas using the check boxes, or select the parent to select it and all child zones, then click Subscribe and Close.
• To unsubscribe from areas you own, select the area(s), then click Unsubscribe, then close the tool.
