Understanding Searching in Tables
You can search for data and the table will only show rows matching the search criteria. Any rows containing data that matches the criteria will dynamically highlight the matching text. The searching sequence is as follows:
1. Find and highlight text in any list by clicking the
Search icon (
) in the column heading. The
Search field will be displayed.
2. Enter your search criteria. As you type, the table will begin to highlight matches and hide any rows that do not contain the criteria.
3. To clear the text entered in the
Search field, click the
Clear button (
4. To close the
Close button (
