Understanding Map Settings
Click the Map Settings button (Magnifying glass search button.) to display the map settings dialog box. Options displayed in this dialog box allow you to change Map view options.
• Show Device Symbol Rotation: When deselected, the map will display device symbols at a uniform angle.
• Enable Conductor Dashed-Phase Lines: When selected, visualizes the number of phases on each conductor.
• Symbol Scale: Allows you to change the size of the device symbols away from the default value of 1.
• Big Symbol Scale: Allows you to change the size of big device symbols away from the default value of 1.
• Big Symbol Zoom Level: Allows you to select the level at which big symbols are hidden or displayed.
• Line Scale: Allows you to change the conductor widths away from the default value of 1.
• Condition Offset Scale: Allows you to set the distance at which condition symbols are displayed away from the device.
These settings are saved with your User Preferences.
