Searching and Positioning
You can search on assets, customers, and other type of map object.
1. Click the Search button (Magnifying glass search button.) to open the Map Search dialog box.
2. Choose the Search Type from the drop‑down list.
3. Enter the text to search for.
4. Select a wildcard option, if applicable.
5. Click the Magnifying glass search button. Search button to execute the search:
• If there is only one match, the dialog box will close and the Map will reposition.
• If there are multiple matches, they will be displayed in a Search Results dialog box. Select a row in the Search Selection Results dialog box and click the Select button (Check mark select button.) to select and position the Map on that item.
