Map View Menu Options
You can change the way the Map displays certain information through options in the Map's View menu.
Conductor Color Options
The Conductor Color options allow you to select whether to view conductors by Feeder, Phase, or Nominal Voltage.
Map Background Color
The Map Background Color allows you to select the map background color. You can choose to follow the theme set in the Settings dialog box or select either the Dark (1) or Light (2) theme regardless of the theme used in the Flex Operations tab/window.
Annotated screen captures of the map in 1) Dark and 2) Light themes.
Map Color Legend...
The Map Color Legend allows you to view the meaning of each color.
Find Assessments
The Triangle with ! in the middle. Find Assessments option allows you to list and position the Map on Assessments.
