Using the Trace Feature
For a selected object, click the Diamond shape with arrow icon that launches a map application. Trace... button to open the Trace panel. From the Trace panel, you can do the following:
• To perform a trace, select the trace criteria (Trace To, Trace Direction, and Trace Phases), and then click the Diamond shape with arrow icon that launches a map application. Perform Trace button. The network will highlight the trace path.
• To clear the trace, click the Diamond shape with arrow icon that launches a map application. Clear Trace button.
• To refresh the trace with real-time conditions, click the Diamond shape with arrow icon that launches a map application. Refresh Trace button.
• To focus on the endpoint of the trace, click the Diamond shape with arrow icon that launches a map application. Target Endpoints button.
• To see the full extent of the trace, click the Diamond shape with arrow icon that launches a map application. Display Extent button.
• To focus on the selected object, click the Diamond shape with arrow icon that launches a map application. Display Trace Object button.
• To get a list (table) of devices included in the trace, click the Diamond shape with arrow icon that launches a map application. Open Trace Results... button. If you wish to see a subset of devices involved in the trace, select the device type from the Trace Results drop‑down list.
See “Executing Traces” for more information on trace options.
