Record Patrolling Updates
You can add and update patrolling conditions.
Adding a Patrolling Condition
1. In the Map, click to select a device or conductor.
2. From the
Selection Panel, select
Patrol Status, and then select the type of patrol condition to add:
Add Patrolling Condition: Adds the condition in a
Patrolling state.
Add Device Patrolled: Adds the patrolling condition of
Device OK.
Network Patrolled: Adds the patrolling condition to
All OK. Highlights all network downstream of the selected device in a patrolled color.
Updating the Status of a Patrolling Condition
1. In the Map, select the patrolling symbol.
2. From the
Selection Panel Patrolling panel, select
Edit Condition from the
Tag/Note menu.
3. In the Patrolling Condition Details dialog box, change the condition status and add a description in the Text field, then click OK.
Removing a Patrolling Condition
1. In the Map, click to select a patrolling symbol.
2. From the
Remove Condition from the
Tag/Note menu.
