Resources
The specific REST API specifications are available in two formats:
• OpenAPI JSON
• OpenAPI HTML
OpenAPI JSON
The NMS system provides OpenAPI specs for the RestFUL services in JSON format. These are available on the NMS nms-ws server:
• openapi-c2m.json
• openapi-callentry.json
• openapi-damage.json
• openapi-flex.json
• openapi-ivr.json
• openapi-mobile.json
• openapi-swman.json
• openapi-trouble.json
To access them, use the URL to your nms-ws server. For example:
https://nms1.utiltiy.com:7102/nms-ws/openapi-mobile.json
OpenAPI HTML
The NMS system provides OpenAPI specs for the RestFUL services in HTML format. These are part of the NMS release and are located in the $NMS_BASE/dist/install/openapi directory and they are installed into the $OPERATIONS_MODELS/openapi as part of the nms-setup process. Since they are in the $OPERATIONS_MODELS directory, they can be viewed using the NMS lighttpd server on the nmsadmin system, for example:
http://nms1.utility.com/openapi/openapi-mobile.html
These are available on the NMS lighttpd server:
• openapi-c2m.html
• openapi-callentry.html
• openapi-damage.html
• openapi-flex.html
• openapi-ivr.html
• openapi-mobile.html
• openapi-swman.html
• openapi-trouble.html
