Option | Description |
-v | Turn on verbose output. |
-debug | Turn on debug to assist with adapter issues. If debug is turned on, it will turn on verbose output. |
-hourly | to pull hourly data from NOAA |
-weekly | to pull weekly data from NOAA |
-exdb | must run with this option if importing data to a non-NMS database |
-no_proxy | Force the adapter to use no proxy when connecting to the NOAA web services. |
-clean | Remove all forecast data from the PF_WEATHER_ZONE_FORECAST table, which is used by the power flow analysis. |
