Software Configuration
Support for Encrypted Configuration Parameters
Some configuration parameters that are stored in the CES_PARAMETERS database table contain sensitive information, such as authentication credentials, which should be protected. To protect this data, the VALUES column can be encrypted using the Oracle WebLogic Server encrypt utility. This utility encrypts cleartext strings for use with Oracle WebLogic Server. Its output can then be used to populate values in CES_PARAMETERS database table.
Note: For detailed information, see "encrypt" in the Oracle WebLogic Server Command Reference documentation.
Entries in the CES_PARAMETERS database table for the Oracle Utilities Network Management System - ODIN Adapter should have the value 'ODINInterface' in the APP column. The column ATTRIB should contain the name of the configuration parameter and the column VALUE should contain its value.
General Parameters
Parameter
Description
config.enabled
Enable/disable.
Default: true (enabled)
config.nms_url
URL for accessing Oracle Utilities Network Management System. If this parameter is not provided, then it is assumed that ODIN Adapter is deployed on the same Managed Server as cesejb.ear.
config.username
Valid NMS username, which has at least the 'NmsRead' role in WebLogic Server. The adapter will use this username to connect to cesejb.ear.
config.password
Password for the NMS user specified by the ‘config.username’ parameter
Value of this parameter should be encrypted or it should be stored in keystore instead of the database (see Appendix A).
config.strict_odin_format
Strictly adhere to the ODIN outage data format.
Default: true
config.publish.url
URL for publishing outage information.
config.publish.format
Format for publishing outage information.
Valid values:
• xml - outage information is published as XML document
• json - outage information is published in JSON format
Default: xml in strict mode (required by ODIN), otherwise json.
config.publish.period
Period for publishing outage information in minutes.
Default: 15 minutes
config.publish.timeout
Timeout in seconds for web service operations.
Default: 30 seconds
config.outage_id_format
Outage ID format.
Format for generating outage identifiers for point outages.
The '%d' string in the format is replaced with the NMS outage identifier (event index).
When publishing to the Outage Data Initiative Nationwide (ODIN) website the specified format must make the outage ID globally unique.
Default: %d
config.include_spatial_info
Include spatial information with outage data.
Implicitly disabled (set to ‘none’) if config.strict_odin_format is set to 'true'.
Valid values:
• outage - include for point outages
• area - include for area outages
• all - include for point and area outages
• none - do not include spatial information
Default: none
Utility Identifier and Name
When publishing to Outage Data Initiative Nationwide (ODIN) website utility name and id information must be provided.
Parameter
Description
config.utility_id
Utility ID.
Preferably, it is the unique identifier used by the Energy Information Administration for reporting.
config.utility_id_authority
Name of the authority responsible for managing utility ID (Utility, EIA, NERC, and so forth).
config.utility_name
Utility name.
config.utility_name_authority
Name of the authority responsible for managing the utility name (Utility, EIA, NERC, and so forth).
Authentication
Parameter
Description
config.auth.url
URL of OAuth server.
If provided then the credentials specified by the config.auth.user and config.auth.pwd parameters will be used when contacting the OAuth server and the obtained token is then used when publishing outage information.
If not provided, then the configured credentials are used directly when publishing outage information using the basic HTTP authentication mechanism.
config.auth.scope
The scope value used when requesting OAuth token.
config.auth.user
Username/client id.
config.auth.pwd
Password/client secret.
This parameter should be stored in encrypted form.
Geographic Area Mapping
These parameters map outage area types defined in the ODIN specification (borough, county, parish, serviceArea, state, township, ward, zipcode) to the value in the AREA_TYPE column in the GEOGRAPHIC_OUTAGE_AREAS database view.
NULL value indicates that outage area type is not used.
Note: the same column cannot be mapped to multiple area types.
Parameter
Description
config.area_type.zipcode
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘zipcode’ area type.
config.area_type.county
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘county’ area type.
config.area_type.state
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘state’ area type.
config.area_type.township
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘township’ area type.
config.area_type.ward
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘ward’ area type.
config.area_type.parish
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘parish’ area type.
config.area_type.borough
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘borough’ area type.
config.area_type.serviceArea
Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘serviceArea’ area type.
