Grid DERMS Dashboard Configuration
The following SRS Rules can be configured for the Grid DERMS Dashboard.
ENABLE_FLM_HISTORY: Set rule_value_1 to "yes" to be able to see historical data on the dashboard.
ENABLE_DERMS_DASHBOARD_CACHE: The rule_value_1 can be set to "no" to disable the caching or "yes" to enable the caching.
DERMS_CACHE_REFRESH_INTERVAL: The time period values for cache updates in minutes can be modified using this rule.
1. rule_value_integer_1: Time period to update the Edge DERMS Events Cache in.
2. rule_value_integer_2: Time period to update the DER Resources Count Cache in.
3. rule_value_integer_3: DERMS Dashboard Load & Generation Charts - Time period to update the Realtime/Current Hour Cache in.
4. rule_value_integer_4: DERMS Dashboard Load & Generation Charts - Time period to update the Forecast Cache in.
