JBotCommand Methods Reference
The following commands may be called from a JBot command:
Method
Description
getParameter
protected java.lang.String getParameter(java.lang.String key)
This returns the value of a configuration option for this command.
getDefaultmeter
protected java.lang.String getDefaultParameter(java.lang.String key,
java.lang.String defaultValue)
getBooleanParameter
protected boolean getBooleanParameter(java.lang.String key,
boolean defaultValue)
getRequiredBooleanParameter
protected boolean getRequiredBooleanParameter(java.lang.String key)
getRequiredParameter
protected java.lang.String getRequiredParameter(java.lang.String key)
This returns the value of a configuration option for this command. If it does not exist, it throws a JBotException.
getParameterSubset
protected java.util.SortedMap<java.lang.String,java.lang.String> getParameterSubset(java.lang.String prefix)
This will return the parameters in alphabetical order that start with the given prefix.
Parameters
prefix: Prefix of the parameter to match.
Returns
A sorted map of parameters
execute
public abstract void execute() throws java.lang.Exception
This is the method invoked by the CommandProcessor when the command is executed.
Throws
java.lang.Exception
getName
public java.lang.String getName()
Returns command String key.
Returns
java.lang.String
supressBusyCursor
public boolean supressBusyCursor()
Return True if this command should not display the hourglass. This should only be set to true if the command is very fast.
getEvent
public java.lang.Object getEvent()
Returns original event object. It could be any swing events for example.
Returns
java.lang.Object
setStatusFlag
public void setStatusFlag(java.lang.String flag, boolean status)
Set the specified status flag in the DataManager. These statuses determine validation, JButtons' enabled status, etc.
Parameters
flag: the status value
status: the boolean status
getStatusFlag
public boolean getStatusFlag(java.lang.String flag)
Get the value of the specified status flag in the DataManager. These statuses determine validation, JButtons' status, an so forth.
Parameters
Returns
• True: if flag is true
• False: if flag not found or flag is false.
fireStatusChanges
public void fireStatusChanges()
Notifies all interested components that the tool's statuses have changed.
getDataStore
public IDataStore getDataStore(java.lang.String dataStoreKey)
Returns the DataStore with the specified key.
Parameters
dataStoreKey: the String key that describes the DataStore
Returns
The datastore.
getCurrentDataRow
public final IDataRow getCurrentDataRow(java.lang.String dataStore)
A convenience method that will get the current datarow of a datastore.
Parameters
dataStore: the name of the data store.
getJBotEvent
public JBotEvent getJBotEvent()
Returns JBotEvent object.
Returns
com.ces.jbot.JBotEvent
isAbort
public boolean isAbort()
Indicates whether processing of additional commands in this package should be aborted.
setAbort
protected void setAbort(boolean b)
If true, instructs the command processor to not process any additional commands for this event.
getDataSourceValue
protected java.lang.Object getDataSourceValue(java.lang.String dataSource)
Returns the value of a datasource in the form of [datastore].[column name].
Parameters
dataSource: the datasource
Returns
the value
