Supporting Cross-Domain Security
Cross-Domain Security allows a server running nms-ws to be in a different domain from the domain running cesejb.ear. It is a more secure way of configuring security than Global Trust (though Global Trust remains supported).
To enable Cross-Domain Security do the following:
1. Install the January 2025 Weblogic CPU.
2. Use cesejb authentication (defined in WebService.properties)
3. Follow the steps in https://docs.oracle.com/en/middleware/fusion-middleware/weblogic-server/12.2.1.4/secmg/domain.html
Also, if switching from Global to Cross-Domain, change the credentials of one of the domains to a different value. In the console, go under Domain, Security, General, Advanced, Credential.
