Showing Measurements
To show measurements, select Show Measurements... from Edit menu in SCADA Trend Graph tool. The Show Measurements dialog box will open.
Using Show Measurements Dialog Box
Show Measurements Dialog Box Fields
The Measurements table display the list of measurements that are currently hidden in the SCADA Trend Graph tool. The table contains two columns: the unnamed column that contains check-boxes used to select measurements and the Name column that contains measurement names.
Buttons
• The OK button shows trend lines for the selected measurements to the graph and closes the Show Measurements window.
• The Help button opens the online help for this topic.
• The Cancel button closes the Show Measurements window without changing the graph.
Understanding the Trend Alarm List
The Trend Alarm list shows all alarms related to displayed trend in trend graph that have been generated over a selected period of time (the time duration selected in the trend graph). The Trend Alarm list does not condense related alarms so every alarm will be displayed as a row in the table. In addition, operator initiated actions in response to an alarm will be displayed in the Alarm, but will not be displayed in the Alarms list since an operator does not need to be notified of their own actions.
• The Unacknowledged column contains a bell icon (Unacknowledged System or Crew Emergency Alarm icon.) if the alarm is unacknowledged.
• The Priority column contains the priority associated with the alarm. The priority field's background is filled with the priority's associated color while the alarm is not acknowledged.
• The Alarm Time column contains the time the alarm was generated in the field.
• The Class column contains the alarm class associated with the alarm.
• The Category column contains the alarm category associated with the alarm.
• The Attribute column contains the type of SCADA measurement or System alarm.
• The Alarm Message column contains the alarm text, which are configured for the alarm class/category.
• The Phases column contains the phases applicable to the alarm.
• The Phases Present column contains the device's phases whether involved in the alarm condition or not.
Note: Other columns are available. See Understanding Column Display Options for information on showing and hiding columns.
