Understanding the Notifications Indicator
The Notifications bell indicator () will be visible in the banner if you are logged in as a user type that receives (or creates) Notifications.
Note: The type of notifications visible also depends on your permission.
• The bell icon will display the number of unread notifications, if any exist. The background color will depend on the unread notifications' category priority.
• The product standard notification categories are:
Category
Color
Icon
Info: An information notification.
Blue
Warning: A warning notification.
Orange
Critical: A critical notification.
Red
Crew Contact: A critical notification that you need to contact the assigned crew.
Red
ERT beyond current: A warning that the event duration has exceeded the estimated time of restoration.
