Changing Column Order and Display
There are a number of options to reorder (move) and hide columns.
• Select a column heading and drag the column to its desired new position.
• Right click a column header and select Hide Column to hide the column.
• Right click a column header and choose Organize Columns... to open the Columns dialog box that allows you to reorder and hide columns.
• Hide or show columns by deselecting or selecting them, respectively.
• Reorder columns by dragging the column row up or down the list.
• Use the positioning buttons to move the column to the top of the list (first column in table), up one position (left in table), down one position (right in the table), or to the end (last column in the table).
Columns dialog box controls. Leftmost button moves the column to the top of the list, next button moves the column up one row, next button moves the column down one row, and last button moves the column to the last row.
Example
The Events List table showing the Status column [1] selected and displayed, [2] deselected and hidden, and [3] displayed and moved to the left in the table.
Illustration of the Columns dialog box with column names listed next to check boxes that, when selected, display the column in the table. Corresponding examples of how the table is rendered given the scenario. 1) Status check box selected; 2) Status check box deselected; 3) Status check box selected and moved up in the Columns dialog box.
