Understanding Quick Filters
Quick Filters allow you to filter based on values in a column. To perform a quick filter, hover your mouse over a column heading and then click the filter button (Filter button showing funnel icon with darker selected background.) in the drop down toolbar. In the filter panel that opens, select an item to filter or enter the criteria in the Search box. Once you have filtered on a column, the filter icon (Filter button showing funnel icon with darker selected background.) will be displayed in the column header and a quick filter breadcrumb will display the filter results and criteria.
To remove the quick filter, click the Reset All Column Filters button (Reset All Column Filters icon). The current quick filters can be saved along with the current search folder filters as a new filter in the personal section, by clicking the Save the Current Filters button (Save filter icon), then providing a name for the new filter. If a folder in the Personal filters section is selected, the new filter will be saved there, otherwise it will be saved in the root of the Personal section. The new filter will have a different icon (Personal quick filter icon that is a filter in front of a magnifying glass.) indicating that there are quick filters associated with it, and when that filter is selected in the tree, the table filtering will be changed to match that saved with the filter.
Example:
Filtering on the #Out column [1] for a value of 1 [2] with the Save the Current Filters button [3].Example of quick filtering where (1) is the column being filtered, (2) is the filter criteria, and (3) is the Save Current Filters button being available
Note: Quick filtering is applied to all filtered views, but it is removed when you close the tool or log off.
