Printing Lists and Details
Print menu options are available for lists and detail forms. Selecting the Print... option from a window's File menu, opens a print preview dialog box that allows you to print the contents of the page.
Selecting the Print... option for a details page (for example, from Event or Switching Sheet Details) invokes a Print Options dialog box that allows you to select what to print.
• Print the current tab
• Print selected tabs
You can select the tabs to print from the list of tabs in the dialog box.
Click OK to open a print preview dialog box displaying the content that will be output. The print preview dialog allows you to print to a printer or save to PDF.
