Understanding Common Events and Crews Page Controls
Icons in the Events and Crews panes' title bars allow you to control the position and display of the panes.Buttons available in the Events and Crews title bars allow you to control the position and display of the panes.
1. Pop Out: Pop the Events and Crews tab out to a separate browser tab/window.
2. Side‑By‑Side Orientation: rearranges the Events and Crews panes to be side‑by‑side. Once the panes are side‑by‑side, the icon will change to a square divided horizontally to indicate that you may switch the pane orientation to Events on top of Crews.
3. Minimize Pane: Click to minimize the pane to its title bar, which will maximize the other pane. When a pane is minimized, you can display it temporarily by clicking the title bar. The button will change to a Restore button (Button to restore a minimized or maximized pane to its standard position.); click the Restore button to restore the pane to its previous layout.
4. Maximize Pane: Click to maximize the pane, which will minimize the other pane. Alternatively, you can double-click the title bar to maximize it. The button will change to a Restore button (Button to restore a minimized or maximized pane to its standard position.); click the Restore button to restore the pane to its previous layout.
5. Close Events and Crews Tab (Button to close the Events and Crews tab.): Click to close the pane.
Note: These pane controls are also available when viewing a safety document associated with a switching sheet.
