View an Outage Event on the Map
To view the location of an outage event on the Map, select an event then click the Focus button (Focus target button.). The Map displays as a new tab in your browser, but, if desired, you can detach it and display side-by-side with your Events and Crews tool.
When enabled, the Map’s Selection panel provides the actions available on a selected device.
Note: For information on using the Flex Operations Map see the Working with the Map.
