Steps Tab Toolbar and Context Menus
When the Steps tab is selected, additional buttons are displayed in the toolbar and Actions menu for actions that you can perform. If a button is grayed, then that action is not currently permitted.
Most toolbar actions are also available through a context menu that is displayed when you right-click a step row. The context menu contains some options that do not appear on the toolbar.
The
Understanding Steps Tab Actions for descriptions of the actions that can be performed on the Steps tab with toolbar buttons, keyboard shortcuts, and/or context menu items with the following exceptions:
1. Actions not available in Flex
• Clear crews
• Copy steps as go-back steps
2. Actions only available in Flex Operations:
• Clear Clipboard: Clears copied steps from your computer clipboard.
• Edit Step: Opens Edit Step dialog.
• Undo: Reverts the latest cut, paste, or delete action.
Refer to the
Using the Steps Tab for the list of columns available in the Steps table.
