Get Directions or Access Other Map Views
The Diamond shape with arrow icon that launches a map application. Navigate menu allows you to select from options based on the object selected.
• Directions to Location opens a navigation site (in a new browser tab) to get directions to the object's location.
• Cycle Available Geographic and Internal Map Views cycles through different views of the device (schematics, geographic, and so forth).
• View Full Extent zooms out to show the device in relation to its network.
• Diamond shape with arrow icon that launches a map application. View in Geographic Map changes the Map to the geographic view.
• Diamond shape with arrow icon that launches a map application. View Schematic Map changes the Map to the schematic view.
• Diamond shape with arrow icon that launches a map application. View Single-Feeder Map changes the Map to show the feeder one line view.
Note: When using Flex Operations on a touchscreen, tap on a device to display a popup menu which enables you to:
• Display the selection panel
• View the device’s tooltip
• Display the device’s right-click menu
