Actions Menu
Menu Option
Description
Toolbar Icon
Trend Graph Options…
Opens Trends Graph Options dialog.
Rescale Trends Graph
Sets the date range of the trends graph to the currently visible portion.
Outage Summary Information
The expandable region/zone tree displays outage information for all regions you are subscribed to. It supports sorting, but not filtering.
Outage summary information includes:
• The Region column contains the region name. If a region has child regions, this column allows you to expand or collapse rows for the child regions.
• The Est Restore Time column contains the estimated restoration time (ERT) for events in that region.
• The Feeders Out column contains the number of outages on feeder breaker devices.
• The # Customers Served column contains the total number of customers served by the utility for the region.
• The # Customers Out column contains the total number of customers experiencing an outage for the region.
• The # Critical column contains the total number of critical customers experiencing an outage for the region.
• The # Calls column contains the total number of customer calls received for the region.
• The # Service Outages column contains the total number of service outages for the region.
• The # Device Outages column contains the total number of device outages for the region.
• The # To Do Outages column contains the total number of outages that do not have a crew en route or onsite.
The outage summary information may be based on the current time or a user selected time; the Summary Time is the time when the currently displayed outage summary information was generated. To select a date and time parameter, deselect Use Current Time, and enter the desired date and time in the Display Summary As Of field.
