Understanding Safety Documents in Flex Operations
Safety documents may be created, edited, and instructed using Flex Operations. The Safety Documents tool is used to create and open safety documents. Select Safety Documents from the Tool Selector to open the Safety Documents tool.
Understanding the Safety Documents List
Once opened, the Safety Documents tool displays the safety documents that are in the system; it is equivalent to the Web Workspace Safety Document List.
From the Safety Documents tool, you may open an existing safety document or create a safety document.
• To open an existing safety document, you may either right-click and select Edit... from the context menu or double-click the safety document's row.
• To create a new safety document, from the File menu, select New, and then select one of the safety document types.
Safety documents in Flex Operations are very similar to safety documents in Web Workspace. The major differences are in how device lists are managed. See
Working with Safety Documents for more information on the common safety document components.
