Context Menu Options
• View on Map... focuses the Map Viewer on the selected device.
• Start Device Recording triggers the safety document to listen for device selections in the Map Viewer so that they can be added to the list. This will change the label for the list to Tag Points (Recording). To turn off recording, select the Stop Device Selection Recording option on the safety document's toolbar.
• Remove Device is used to remove devices from the list.
