To change a previous response, click the
Edit button (
) beside a completed step. The guided process will go back to the step that you want to change. Depending on the change being made, the guided process may reset subsequent questions (that depended on that response) and then take you through that path; otherwise, you will be returned to where you were before clicking the edit button.
