High-Level Messages
The Oracle Utilities Network Management System - Oracle Field Service Adapter responds several commands sent as high-level messages.
High-level message can be sent using Action command-line utility.
Action any.publisher* ejb client NMS-OFS command <message>
Following messages are supported:
RELOAD - Forces adapter to reload configuration and then initiates synchronization sequence.
RESYNC - Initiates synchronization sequence.
STOP - Temporarily stops the adapter.
START - Re-starts previously stopped adapter.
