Data Requirements
Model
FLA only requires impedance data to accurately determine fault currents. In particular this should be provided on equivalent sources, transformers and conductors.
Due to its minimal data requirements, FLA is also a good choice as a first ADMS application to be implemented.
SCADA
FLA requires the following data from SCADA:
Device Status (Optional)
Fault Indicators
Fault Currents
