Role | Description |
ces_rw | Read-write role. This role has read and write privileges to the production data. It can delete from, update to, and insert to, all of the production tablespace objects. |
ces_ro | Read-only role. This role can only connect and select data from the production tablespace objects. Note: Certain security tables, such as ces_users, are excluded from the view of the ces_ro role. |
User | Description |
[project_admin] | The [project_admin] Oracle user is the owner of the admin schema and the production tablespace. This user has a ces_rw role and maintains full Data Definition Language control of the data elements in the production tablespace. This user is used during initial setup and when installing patches. |
[project]_1 | The [project]_1 Oracle user is the owner of the read/write schema. The user has the ces_rw role. This schema only contains synonyms to objects in the [project]_admin schema and has select/insert/update/delete/execute (Data Manipulation Language) permission on [project]_admin schema objects. This user is used for most day-to-day operations. |
[project]_1_ro | The [project]_1_ro Oracle user is the application user. This user has a ces_ro role to the production tablespace. |
[project]_2 | The [project]_2 Oracle user has the same purpose as the [project]_1 user, except it is used by the second environment in dual-environment configuration. |
[project]_2_ro | The [project]_2_ro Oracle user has the same purpose as the [project]_1_ro user, except it is used by the second environment in dual-environment configuration. |
[project]_customers | The [project]_customers user has full privileges to the customer data tablespace only and no privileges on the production tablespace. |
