CES_PARAMETERS
The CES_PARAMETERS table stores various configuration options used by NMS and some of its adapters.
CES_PARAMETERS Schema
The APP column is "NMS" for NMS configuration parameters. Other values are used for specific adapters.
Site-specific Parameters
Some parameters are site-specific (see the documentation for each individual parameter). For these parameters, the SITE column must be the NMS_SITE_NAME environment variable at the site to which the parameter applies. For each such parameter, one entry must exist for each site.
Parameters which are not site-specific should have a SITE value of all.
Environment-Specific Parameters
In Dual-Environment Configuration, some parameters are environment-specific (see the documentation for each individual parameter). Different values are used in environment 1 and environment 2. These parameters are configured in two different files as described below
Configuration
CES_PARAMETERS entries are configured in the following three files.
[project]_parameters.sql
Parameters which are neither site-specific nor environment-specific are configured in this file.
[project]_site_parameters_1.sql
Parameters which are site-specific or environment-specific are configured in this file. This file is used for environment number 1 based in the NMS_ENVIRONMENT variable.
[project]_site_parameters_2.sql
Parameters which are site-specific or environment-specific are configured in this file. This file is used for environment number 2 based in the NMS_ENVIRONMENT variable.
NMS_PARAMETERS_VIEW
The NMS_PARAMETERS_VIEW view in the database is a view of the CES_PARAMETERS table that only includes the parameters that apply to the current site. This view includes all columns in CES_PARAMETERS except for SITE.
