OMS_APPOINTMENT_TYPES Schema | ||
Column Name | Type | Description |
APPT_TYPE | INTEGER NOT NULL | Appointment type. Primary key |
DISPLAY_ORDER | INTEGER | Order in which appointments types are displayed |
SHORT_DESC | VARCHAR2(32) NOT NULL | Short description of appointment type. Used for display to user. |
DESCRIPTION | VARCHAR2(256) | Long description of appointment type. |
