Site Installation and Configuration
Follow the instructions in the “Installing and Preparing Oracle Site Guard” chapter of Site Guard Administrator’s Guide to prepare Oracle Site Guard, discover targets, and create a Generic System for each NMS site with the following targets:
• Database Instance
• Oracle WebLogic Domain
• Oracle Utilities NMS (if installed)
• Host targets that NMS services, WebLogic, and Database Instance run on.
• Any other targets for external adapters.
The WebLogic Node Manager must be configured to start the Administration Server in order for Enterprise Manager to control it. See the "Using Node Manager" chapter of Administering Node Manager for Oracle WebLogic Server. It is recommended that Oracle Utilities NMS targets are made the key members of the system and that Availability Criteria is set to “Any Of The Key Members.” With this configuration, the system will be shown as available if either of the NMS instances in Dual-Environment Configuration is available.
Continue following the instructions in the “Installing and Preparing Oracle Site Guard” chapter of Site Guard Administrator’s Guide to create credentials.
Follow the instructions in the “Configuring Oracle Site Guard” chapter of Site Guard Administrator’s Guide to create configuration for Primary and Standby sites and to associate credentials with each generic system.
