Installation
The installation should be done according to the guidelines taught in the Oracle Utilities Network Management System’s System Administration class and follow all recommended procedures for system configuration. The software should be installed on servers and clients in a configuration that meets the requirements stated in the Architecture Guidelines section of Chapter 1 for the installed modules. The installation also should comply with the required operating system level and patches identified in the Oracle Utilities Network Management System Quick Install Guide. The utilized Oracle Utilities Network Management System software modules should have all dependent Oracle Utilities Network Management System software modules installed and configured. The required third-party products should be installed and at the supported release level as stated in the Oracle Utilities Network Management System Quick Install Guide for the installed release.
