Modeling and GIS Integration
The following sections describe some recommended guidelines to follow when you integrate Oracle Utilities Network Management System with a GIS.
GIS Model Extractor
The GIS extractor utilized should either be supported by Oracle or by one of our modeling partners. The extractor should produce Oracle standard model preprocessor (MP) files and utilize the Oracle conventions for model building and an approved incremental update process.
Standard Preprocessor
The Oracle Utilities Network Management System standard preprocessor supports eighteen different rules that allow for data translation (for instance, expand elbows, or add recloser bypass switch). It is acceptable to use as many of these rules as necessary to build an acceptable operations model. The standard preprocessor takes as input model preprocessor (MP) files and produces Oracle standard model build (MB) files - generally on a feeder or substation basis but possibly on a geographic tile basis.
Device Types and Attributes
Select which device types (classes) are used from the standard model definition, mapping the customer's GIS data to these existing classes.
• Define unique class alias names based on available GIS attribute(s).
• Select which attributes are used from the standard model definition (providing at a minimum those necessary for the required modules), again mapping the customer's GIS data to the existing attributes.
• Utilize Oracle-provided modeling workbooks to define the model used for the project, which is used to generate the project classes and inheritance.
• The name of any device may be constructed from one or more GIS attributes.
Software Configuration Dependencies On Device Types
There are a number of NMS software configuration aspects that depend upon the device types that are chosen to be built within the NMS data model. In so far as the data model can change for different facilities, the software configuration must be adapted. The following configuration settings are dependent upon the resulting NMS model definition and require adaptation for every project. These configurations are generated automatically by Oracle to match the defined NMS model.
• Control Tool panels
• Trouble Stop Classes
• Symbology mapping and symbol set
