Directory/ Files | Description |
SYMBOLS | Contains the defined symbol sets for the presentation of all objects. (Convention only. May be moved elsewhere.) |
drawings | Contains the drawing and documentation files that can be associated with objects in the model. (Convention only. May be moved elsewhere.) |
errors | Contains the output files of the model builder specifically related to errors and patch processing. The Model Build patch log files are named in Patch[patch_number].log format. Preprocessor map log files are typically named in [map_name].log format. |
*.mac | Textual representations of the background maps. The background map files corresponding to the *.mad files. These files are used by the Viewer to present background graphic information (boundaries, roads, text, etc.). |
*.mad | Textual representations of the electrical maps. The map files used by the Viewer when presenting graphic information correlated to the network information stored in the database. It is essential to keep the database and the maps synchronized to ensure proper presentation and map conductivity. |
mp | The mp directory is the location of model preprocessor import files, [mapname].mp or directories, [mapset].mpd. This is project dependent however most projects will import .mp files. |
patches | Contains [mapname].mb files and/or [mapname].mbd directories. These files define the model build transactions that will be submitted to the model. Files are moved into the done subdirectory after they have been submitted. |
reports | This directory contains difference reports, which list all changes being introduced into the model for each patch. These are only generated if MBService is running with the -report option. |
