Vendor | Product | Version | Notes |
Oracle | Active Data Guard | 19.14+ | Required for High Availability. This is a licensed option to the Oracle RDBMS Enterprise Edition. |
Oracle | Oracle Analytics Server | 6.4 | Used for business intelligence reports and for printing and e-mailing web switching plans. |
Oracle | Enterprise Manager | 13.4 | Required for High Availability. |
Oracle | Java Developer Kit (JDK)/Java Runtime Environment (JRE) | 1.8.0_351+ | Used by Java GUI components and web-service based interfaces (Client and Server side) |
• 64-bit Java is required for most NMS models. 32-bit Java may be sufficient for some non-production NMS environments. | |||
Oracle | Live Energy Connect | 7.1+ (Windows) 8.0 (Linux) | Needed for the SCADA Adapter |
Oracle | Oracle Database Lifecycle Management Pack | 13.4 | Required for High Availability. This is a licensed option to the Oracle Enterprise Manager. |
Oracle | Oracle RDBMS Enterprise Edition Server | 19.14+ | Required for core Oracle Utilities Network Management System functionality. |
Oracle | Oracle RDBMS Full Client | 19.3+ | Required for core Oracle Utilities Network Management functionality |
Oracle | Oracle WebLogic Server Standard, Enterprise, or Suite Editions 12c, Fusion Middleware Infrastructure | 12.2.1.4+ | Used by Java GUI components and web-service based interfaces |
Oracle | Site Guard | 13.4 | Required for High Availability. This is included in the licenses for Oracle Database Lifecycle Management Pack and WebLogic Server Management Pack Enterprise Edition. |
Oracle | WebLogic Server Management Pack Enterprise Edition | 13.4 | Required for High Availability. This is a licensed option to the Oracle Enterprise Manager. |
Apache | ZooKeeper | 3.8.0-1 | Used by the NMS Monitor component of High Availability |
Esri | ArcGIS/ArcFM | 10.x | Esri GIS |
Esri | ArcGIS Pro Utility Network | 2.x | Esri Utility Network Model GIS |
GE | Smallworld GIS | 4.x | Smallworld GIS |
Grzegorz Kowal | Launch4j Executable Wrapper | 3.14 | Used with NSIS to install standalone Java client applications from the Configuration Assistant. |
IBM | MQ | 8.0.0.4 | Needed for Generic IBM MQ Adapters |
Intergraph | G/Electric GIS | 9.3.x, 10.x | Intergraph GIS |
nodesjs.org | NodeJS | 14.17+ | NodeJS is a build and package management tool used to build the Operations Mobile Application |
Nullsoft | NSIS (Nullsoft Scriptable Install System) | 3.08 | Used with Launch4j to install standalone Java client applications from the Configuration Assistant. |
The OpenSSL Project | OpenSSL | 1.1.1lq | Used for secure communication between SwService (used in CVR and FLISR) and WebLogic server |
Apple | iOS | 15.x+ | Used to run Flex Operations and Operations Mobile Application clients |
Apple | Safari | 15+ | Supported for installing the Operations Mobile Application PWA app on an iOS device. Also supported for the Flex Operations application on an iOS device. |
Google | Android | 10.x+ | Used to run Flex Operations and Operations Mobile Application clients |
Google | Chrome | 108+ | Used to display online help and when using Java Web Start to download the NMS Java client applications. Also supported for the Flex Operations application as well as for installing the Operations Mobile Application PWA app on Windows and Android devices. |
Microsoft | Edge (Chromium) | 108+ | Used to display online help and when using Java Web Start to download the NMS Java client applications. Also supported for the Flex Operations application as well as for installing the Operations Mobile Application PWA app on a Windows device. |
Microsoft | Windows | 10, 11 (64-bit) | Used to run all client applications |
Mozilla | Firefox | 102+ | Used to display online help and when using Java Web Start to download the NMS Java client applications. Also supported for the Flex Operations application. |
