Mobile Archive Restricted Use
The Oracle Utilities Network Management System Program includes one or more mobile application archives or libraries (each a “Mobile Archive”). Your use of the Mobile Archive is limited to the following:
1. Modify the Mobile Archive to include your custom branding, look and feel, and functionally extensions;
2. Insert your brand or logo where indicated (removing Oracle’s brands, logos, and trademarks, if any, but not removing or modifying any Oracle copyright statements except as stated in the following paragraph) in the Mobile Archive;
3. If you modify the Mobile Archive as set forth above, append the word “Portions” before any Oracle copyright statement (as an example, “Portions Copyright © 2015, Oracle and/or its affiliates. All rights reserved.”)
4. Compile, complete, and sign the Mobile Archive with your own mobile operating system-specific certificate(s), thereby creating a mobile application (“Mobile Application”); and
5. Distribute the Mobile Application within your enterprise or entity to your internal users and/or to your third party end users (“End Users”). You may not distribute the Mobile Archive to your internal end users except to the extent necessary for the creation of the Mobile Application. You may not distribute the Mobile Archive to End Users.
With respect to your distribution of the Mobile Archive as included in a Mobile Application (a) you must abide by the terms and conditions in the Programs license agreement pertaining to separately licensed third party technology and the separate terms applying to such technology, and (b) these terms constitute your order under which you are permitted to distribute the Mobile Archive portion of the Programs. With respect to creating a Mobile Application, you acknowledge that you must separately agree to and abide by license terms with the applicable mobile operating system provider and possibly other third parties. For example, for iOS applications, you agree that the Mobile Application, in whole or in part, may not be installed on a mobile device or executed except as incorporated into an iOS application that has been signed using an appropriate Apple-issued certificate that you obtained directly from Apple and that is deployed in full compliance with your agreement with Oracle (including these terms) and license terms set forth in a separate agreement between you and Apple.
