The table below identifies the color coding used in the Work Agenda Feeder column to indicate the feeder's FLISR automation status. This is enabled when a cell or row coloring option is selected from the Web Workspace User menu's Table Settings sub-menu (see “Understanding the Table Settings Menu” for more information)..
