Flex Operations Features
Support Flex Operations on Tablet-sized Devices
Flex Operations is now supported on tablet-sized devices such as Apple iPads, Android tablets, or Windows tablets. This includes support for touch interaction such as swiping and pinching to navigate tables, forms and the Map. Device responsiveness support includes the ability for Flex Operations to automatically change layout to support different screen sizes and screen orientations (landscape vs. portrait).
Minimum supported tablet specifications: 10.2" screen, minimum RAM 8GB.
Support Pinging AMI Meters from Flex Operations
Flex Operations supports selecting events from the Event list to confirm power status or select one or more rows in the AMI Customer List to ping for Power Status, Voltage, and Load-side connectivity, and the ability to view the Ping History for each of the ping types.
It also provides an AMI Requests tab to view and manage ping requests. The functionality is similar to the AMI pinging capability that exists in the Web Workspace client.
