Operations Mobile Application (OMA) Features
Support Pinging AMI Meters from Operations Mobile Application
Operations Mobile Application (OMA) supports viewing the list of AMI customers associated to a crew's assigned event or to a device, and then be able to select one or more meters to ping. The same three ping types available in NMS of Power Status, Voltage, and Load-side connectivity are supported. The ping results are then viewed within the AMI Customer List. In addition, Ping History is available for all three ping types, similar to the AMI pinging capability that exists in the Web Workspace client.
