User Experience (UX) Features
Common Network Viewer for Flex Operations and Operations Mobile Application (OMA)
This feature provides a common look and feel for map user interaction for Flex Operations and Operations Mobile Application (OMA).
The Common Network Viewer improves the performance of map interactions such as panning and zooming, while also includes enhanced display of conductor highlights, phases, text annotations, map backdrops, and other network information.
User-configurable settings are stored with the User's profile in Flex Operations and set/stored at the device-level for OMA.
Most System Manager configuration is now managed in a single place, rather than across different files and file locations specific to each application, thus simplifying configuration and maintenance.
Improved Display of Notifications in Work Agenda
Traditionally, each configured "Notify" for a Work Agenda event generates a new separate "NFY" (Notify) row in the Work Agenda. This could clutter the Work Agenda.
In this release, a new, "In-Line Notify" feature eliminates the creation of additional Notify rows in the Work Agenda.
A new column in the Work Agenda shows events that have Notify notifications.
Mousing over the NFY indicator displays a tool tip containing the notify text (if multiple Notify notifications are associated with an event, the text for each notify is displayed on a new line in the tool tip). The user can easily acknowledge the event's Notify notifications from the right-click menu.
