| Option | Description | Toolbar Icon |
| Export Table... | Opens a dialog box that allows you to save the current table view data to a comma separated value (csv) file. | |
| Print… | Opens the Print dialog box, which allows you to print the currently selected report. | |
| Exit | Closes the Topology Validation Viewer window. |
|  Run Validation... | Opens the Run Validation dialog box, which allows you to choose the reports to run and select criteria for them. | |
|  View... | Focuses the Viewer on the selected device. | |
|  Refresh | Reloads all reports. |
| Topology Validation Viewer Help | Opens the Oracle Utilities Network Management System's online help content for the Topology Validation Viewer. |
