Status Code | Description |
T-NEW | A new Protection Scheme event. |
T-CNL | The protection scheme event has been canceled. |
T-INC | The protection scheme event has been completed but information needs to be entered into the Event Details window. |
T-CMP | The protection scheme event has been completed. |
DMS Status | Description |
Protection Scheme Generated | The protection scheme event and associated switching plan have been generated. |
Protection Scheme Automatically Executing | The protection scheme switching plan is currently being executed automatically by the NMS. |
Protection Scheme Automatically Executed | The NMS has completed executing the protection scheme switching plan. |
Protection Scheme Automatic Execution Failed | The NMS system failed to execute the protection scheme switching plan. |
Protection Scheme Manually Aborted | The protection scheme switching plan was aborted. |
Protection Scheme Integrity Check Generated | The protection scheme event and associated switching plan have been generated as a result of a background integrity check. |
