NMS Services
The FLEX SCADA sends changes in measurement values to an instance of the RTAdapter nms service. The RTAdapter instance command line arguments must be configured as follows:
•	The –dir command line option must be set so that the instance processes the RDBMS tables scada_digital_in and scada_analog_in.
•	If you still require RTAdapter to process files for existing SCADA interfaces then multiple instances of RTAdapter should be configured on the system each handling a unique scada id.
•	The –control command line argument must not be set.
•	The –interval command line argument must be set to as low as possible a value (for example, 1).
