Monitoring Data Source | How Monitored | Who Monitors | Usage | Notes |
WebLogic cesejb deployment | REST API call | NMS Monitor | Determine deployment status and if it is reachable. | Multiple cesejb URLs can be configured. |
WebLogic nms-ws deployment | REST API call | NMS Monitor | Determine deployment status and if it is reachable. | Multiple nms-ws URLs can be configured. |
Database | Database queries to NMS_VERSION, NMS_CURRENT_SITE, and V$DATABASE tables. | NMS Monitor | Query which NMS environments are active or staging, the current NMS site, the NMS version from the last nms-setup run, and the database role (PRIMARY vs STANDBY). | |
NMS Services | Local process executes oem-util command and reads the files $HOME/.nmsrc, $NMS_HOME/.nms-site-rc, and $NMS_ROOT/nms/inventory/nms-version.xml. NMS Monitor makes REST API call to get this information. The NMS Agent (a process running locally on the environment where NMS Services run) does the following: • Reads $HOME/.nmsrc and $NMS_HOME/.nms-site-rc to get NMS environment variables • Reads $NMS_ROOT/nms/inventory/nms-version.xml to get the installed NMS version • Executes the oem-util command to get the services status from SMService. | NMS Agent | Determine services status, installed NMS version, and NMS_SITE_NAME environment variable. | Each NMS environment in dual-environment configuration will have its own NMS Agent. |
WebLogic Admin Server | Several REST API calls to the WebLogic RESTful management interface. | NMS Monitor | Determine mapping between URLs, deployments, and WebLogic servers and get WebLogic's status of each. Determine deployment versions. | If unable to contact Admin Server, the most recently retrieved results are used. |
Enterprise Manager | Several emcli commands. | NMS Monitor | Retrieve Site Guard information: • Site Names for the Sites configuration page. • Operation Plans for the Operation Plans configuration page. | Polled every minute instead of using Polling Interval. |
Component | Description | Component Status | Critical Component |
Web Gateway | WebLogic deployment used for Web Workspace, Web Call Entry, and so forth. | • Unknown if not configured. • Error if unable to map application(s) to a WebLogic server. • Down if REST API call fails to get a response, WebLogic managed server state is not RUNNING, or WebLogic server overall health state is failed. • Warn if REST API call succeeds, but shows status of down or WebLogic server overall health state is warn, overloaded, or critical. • Up if REST API call succeeds showing status of up and WebLogic server overall health state is up. If multiple Web Gateway URLs are configured and have different individual statuses, total status will be Warn if at least one application is Up and one or more are Warn. | Yes |
Mobile Gateway | WebLogic deployment used for Operations Mobile Application (OMA) and Flex Operations. | Same as Web Gateway, but for the nms-ws deployment. | No |
Services | NMS backend services. | • Unknown if NMS agent not configured. • Error if unable to reach NMS agent or NMS agent unable to execute oem-util. • Down if unable to communicate with SMService or SMService system state is CRITICAL. • Warn if SMService system state is WARNING or INITIALIZING. • Up if SMService system state is NORMAL. | Yes |
Database | RDBMS used by all of the components listed above. | • Unknown if database not configured. • Down if unable to query database. • Warn if able to query database, but some SQL statements failed. • Up if able to query database. | Yes |
