Network Management System OMS for Water User’s Guide
Audience
Related Documents
Conventions
Resources
Common Features
Launching Modules and Logging In
Launching an Application
Understanding User Types
Logging In
Understanding Common Features
Understanding Module Window Configuration
Using Date/Time Pickers
Working with Tables
Selecting and Deselecting Rows
Selecting a Single Row
Selecting Contiguous Rows
Selecting Noncontiguous Rows
Deselecting Rows
Understanding Column Display Options
Displaying Columns
Unlocking and Locking Columns
Copying Table Data
Exporting Table Data
Understanding Table Cell Tooltips
Sorting Data Tables
Using the Sort Dialog Box
Creating a User-Defined Sort
Quick Sorting
Filtering Data Tables
Creating and Editing Filters Using the Edit Filter Dialog Box
Creating a User-Defined Filter
Editing and Renaming Filters
Deleting a Filter
Understanding Operators
Dynamic Filtering
Auto Filtering
Organizing Filters and Folders
Showing, Hiding, and Revealing the Filters Pane
Creating Folders and Sub Folders
Moving and Copying Filters and Folders
Favorite Filters
Understanding Printing in Oracle Utilities Network Management System
Setting Print Margins
Web Workspace
Getting Started with Web Workspace
Understanding the Web Workspace Window
Understanding the Web Workspace Menus and Toolbar
Understanding Annunciators
Understanding Windows, Frames, and Dock Panes
Creating Window Frames
Understanding Docked Panes and Standalone Window Tools
Adjusting Window Size
Switching Between Tools Using the Keyboard
Saving and Restoring Workspace Preferences
Saving Your Preferences
Restoring to Default Preferences
Managing Your Workspace Layout
Understanding the Manage Workspace Layouts Dialog Box
Understanding Conditional Formatting
Global and Personal Conditional Formatting
Applying Conditional Formatting to a Table
Conditional Formatting Dialog
Understanding the Edit Rule Dialog Box
Understanding Conditional Formatting Precedence Rules
Quick Start for Effective Conditional Formatting
Conditional Formatting Best Practice
Quickly Apply a Formatting Rule
Apply a Formatting Rule to More than One Cell
Apply a Formatting Rule Based on Multiple Matching Conditions
Add Personal Conditional Formatting
Promoting Personal Conditional Formatting to Global Formatting
Taking Authority for Control Zones
Using the Authority Tool
Authority Tool Fields
Authority Tool Menus
Subscribing to a Control Zone
Subscribing to an Authority Group
Unsubscribing from a Control Zone
Searching for a Zone
Changing the Rule Set
Creating an Event
Using the Work Agenda
Opening Work Agenda Windows
Understanding Work Agenda (Filtered) Views
Understanding Work Agenda Standard Global Filters
Using Work Agenda Menus and Toolbars
File Menu
Understanding Work Agenda Data Display
Understanding the Work Agenda Summary Row
Understanding the Work Agenda Events List
Sorting, Selecting, and Locking Events List Columns
Using the Events List Condensed and Sub-Events Views
Using the Work Agenda Reading Pane
Acknowledging Events
Clearing Notifications
Using the Viewer
Starting the Viewer
Understanding the Viewer
Understanding the Viewer Drawing Area
Understanding the Viewer Message Area
Using the Viewer Menus and Toolbar
Additional Viewer Toolbar Options
Saving Viewer Preferences
Understanding Viewer Tooltips
Understanding Viewer Context Menu Options
Displaying Asset Details
Viewing Asset Attribute Information from the Viewer
About the Attributes Window
Understanding Viewer Coloring
Viewing the Color Legend
Viewing the Highlight Legend
Searching and Loading Viewer Maps
Using the Search Tool to Locate Map Areas and Objects
Loading and Unloading Viewer Maps
Navigating in the Viewer
Navigating Using Mouse Controls
Scaling Symbols and Text
Displaying Pointer Coordinates
Viewer Focus
Focus on Viewer Selection
Focus on Selection Made in another Window
Using Lens Windows
Behaviors of the Lens Window and Viewer Lens Area
Real-Time and Study Mode
Selecting Assets
Asset Selection
Box Selection
Polygon Selection
Multiple Selections
Identifying Symbology
Asset Symbology
Condition Symbology
Pipe Symbology
SCADA Symbology
Hiding and Displaying Viewer Objects
Decluttering the Viewer
Hiding Conditions with Assets
Executing Traces
Trace Types
Using the Trace Dialog Box
Executing a Trace
Inspecting Direct Connections and Navigating to Connected Objects
Using the Commissioning Tool
Commissioning and Decommissioning Assets
Selecting Pending Assets
Using the Commissioning Tool with Web Switching Management
Using the Assessment Tool
Launching the Assessment Tool
Assessment Tool Toolbar Button Actions
Marking Conductors as Assessed
Removing the Assessed Status from Conductors
Removing Conductors from the Lists
Using the Save Case Management Tool
Opening the Save Case Management Tool
Creating a New Save Case
Viewing an Existing Save Case
Viewing Asset Event History
Understanding the Select Scope Pane
Understanding the Event History Pane
Understanding Operations Event Note Pane
Using the Control Tool
Understanding the Control Tool
Control Tool Actions
Highlighting Events in the Work Agenda
Viewing Documents Associated with an Asset
Adding Notes
Notes Dialog Box
Creating a Note
Editing a Note
Deleting a Note
Toggling Call Display
Viewing Associated Customers
Operating Assets
Closing an Asset
Opening an Asset
Instructing Actions
Instructed Actions Pane
Tagging Assets
Understanding the Tags Dialog Box
Placing an Editable Tag
Placing a Non-Editable Tag
Removing a Tag
Editing Editable Tags
Repredicting Upstream/Downstream
Using the Look Ahead Dialog Box
Understanding the Look Ahead Process
Understanding the Look Ahead Dialog Box
Understanding the Control Failure Dialog Box
Buttons
Associating Documents with Assets
Using the Manage Documents Window
Associating a Document with an Asset
Removing a Document Association
Associating Damage Assessments to an Asset
Completing and Instructing Actions
Condition Summaries
Using the Condition Summaries Window
Toolbar and Menu Options
File Menu
Sort Menu
Actions Menu
Help Menu
Using the Conditions Summary Filter Pane
Using Condition Summaries Balloon Details
Editing Conditions
Using the Alarm Displays
Understanding the Alarms List
Alarms Tool Menus and Toolbar
Alarm Priority Pane
Alarms Table
Alarms Filters Applied
The Main Alarm Window
Working with Alarms
Understanding the Abnormal Assets List
Understanding the Alarm History List
Using the User Log
Menus and Toolbar
File Menu
Actions Menu
Help Menu
Adding Entries to the User Log
Adding New User Log Entries
Adding an Associated User Log Entry
Changing Entry Type Before Submitting User Log Entry
Managing Events with Web Trouble Management
Understanding Event Details
Menus and Toolbar
File Menu
Actions Menu
Event Information Pane
Event Details Tabs
Using the Job Actions Tab
Using the Completion Actions Tab
Using the Equipment Failure Tab
Using the Trouble Info Tab
Using the Damage Assessments Tab
Using the Event Log Tab
Using the Steps Tab
Using the Alarms Tab
Using the Attachments Tab
Updating the Estimated Restoration Time
Using the Update Events Window
Updating Multiple Events
Copying Event Details to Related Partial Restoration Events
Completing an Event
Confirm and Restore Outages
Using the Confirm Outages Window
Accessing the Confirm Outages Window
Understanding the Confirm Outages Window Color Coding
Confirm Outages Menus and Toolbar
Creating a Confirmed Service Outage
Creating a Confirmed Secondary Outage
Creating a Confirmed Service and Secondary Outage for the Same Customer
Restoring a Customer with a Confirmed Service or Secondary Outage
Setting Work Queues
Understanding Event Grouping
Group Events Dialog Box
Grouping Events
Understanding Grouping Rules
Behavior of Grouped Events
Relating Events
Unrelating Events
Ungrouping Events
Associating and Unassociating Calls with Assets or Control Zones
Associating Fuzzy Calls
Unassociating/Reassociating a Call from/to an Asset
Working with Stable Predictions
Working with Damage Assessments
Understanding the Damage Assessment Window
Menu and Toolbar Icons
Understanding the Damage Location Section
Understanding the Damage Specifics Section
Understanding the Damaged Assets Section
Understanding the Attachments Section
Creating Fuzzy Damage Assessments
Updating the ERT for Selected Events
Clearing the ERT
Working with the System‑Wide Estimated Restoration Time
Setting the System-Wide Estimated Restoration Time
Clearing the System-Wide Estimated Restoration Time
Managing Crews with Web Trouble Management
Using Crew Actions
Understanding the Crew Actions Window
Menu and Toolbar
Filtering Crew Lists
Understanding Crew Actions Views
Understanding the Crew List View
Understanding the Crew Icons View
Understanding Crew Actions Operations
Activating a Crew
Setting a Crew's Status to On Shift
Setting a Crew's Status to Off Shift
Making a Crew Inactive
Deleting a Crew
Changing Crew Availability
Finding the Event a Crew is En Route To
Transferring a Crew to a Temporary Control Zone
Returning Control of a Transferred Crew
Using Crew Makeup
Understanding the Crew Makeup Window Components
Creating a New Crew
Removing Personnel from a Crew
Removing a Vehicle from a Crew
Editing a Crew
Managing Crew Operations
Assigning a Crew to an Event
Placing a Crew En Route
Placing a Crew Onsite
Placing a Crew Offsite
Suspending a Crew
Releasing a Crew
Crew Operations Using the Advanced Option
Using Crew Info
Opening Crew Info
Understanding Crew Info Window Components
Menus and Toolbar Icons
Understanding Crew Info Fields and Buttons
Understanding the Crew Info Personnel Section
Understanding the Crew Info Vehicles/Equipment Section
Understanding the Crew Info Active Jobs Section
Understanding the Crew Info Current Assignment Section
Working with Crew Assignments
Modifying a Crew Assignment Duration
Changing the Crew Assignment Order
Unassigning a Crew
Placing a Crew En Route to an Assigned Event
Placing a Crew En Route from the Crew Actions Window
Placing a Crew En Route from the Viewer
Placing a Crew En Route from Crew Info
Updating Active Job Event Information
Moving a Crew
Moving a Crew from the Crew Actions Window
Moving a Crew from the Viewer
Moving a Crew from Crew Info
Releasing Crews from an Event
Releasing a Crew from the Active Jobs Pane
Releasing Crews from an Event Selected in the Work Agenda
Releasing a Crew from the Crew Symbol in the Viewer
Releasing Crews from an Event Symbol in the Viewer
Suspending a Crew
Bulk Crew Loading and Deleting (Administrative Users)
Options
Crew CSV Columns
Crew Member CSV Columns
Crew Vehicles CSV Columns
Using Bulk Add/Delete Scripts
Examples
Web Call Entry
Using Web Call Entry
Menus and Toolbars
File Menu
Actions Menu
Options Menu
User Menu
Help Menu
Field Descriptions
Searchable Information
Intersection Search Section
Additional Customer Information
Appointment Request
Callback Request
Request
Customer Comment
Event Information
Crew Information
Planned Outages Information
Searching for a Customer
Searching for a Customer Using the Call ID
Search for a Call using Caller Information
Viewing Call History
Call History User Interface
Call History
Viewing Event History
Cause Factors
Entering a Customer Call
Entering an Informational Call
Entering a Fuzzy Call
Canceling a Customer Call
Canceling All Calls For a Customer Account
Viewing the Outages Summary
Web Callbacks
Overview
The Web Callbacks Window
Menus and Toolbars
Actions Menu
User Menu
Help Menu
Header
Callbacks Table
Callbacks Table Column Features
Callbacks Summary Pane
Assigning Callbacks
Using the Assign Callbacks Window
Assigning Callbacks to Users
Assigning Numbers of Callbacks
Assigning Percentages of Callbacks
Assigning All Remaining Callbacks
Reassigning All Remaining Callbacks
Viewing Callback Assignments
View My Callback Lists Window
Viewing Your Callback Assignments
Canceling Your Callback Assignments
Unassigning Callbacks
Unassigning Callbacks for a Specific Event
Unassigning All of Your Callbacks
Performing Callbacks
Accessing the Perform Callback List
Using the Perform Callbacks List Window
Performing Assigned Callbacks for an Event
Performing Unassigned Callbacks (Next Callback)
Using the Perform Next Callback Window
Performing the Next Unassigned Callback for an Event
Storm Management
Getting Started with Storm Management
Storm Management Full Operations Environment
User Interface Features
Menus
User Menu
Status Bar
Storm Management Information Panes
Storm Management Information Overview
Storm Management Modes
Non-Storm Mode
Storm Mode
Storm Information
Storm Report
Summary Information
Zone Selection
Selecting the Control Zone to View
Using Storm Management
Using ERT Overrides
ERT Override Dialog Box
Turning Off Accessibility of the Estimates
Overriding the Estimates
Changing Publish/Non-Publish or Default ERT Information
Turning Accessibility of Projections Back On/Removing Overrides
Printing ERT Overrides
Manual Overrides
Overriding Historical Averages
Using Storm Mode
Entering Storm Mode
Using Start Storm Dialog Box
Starting a Storm for a Control Zone
Joining Existing Storms
Joining a Control Zone to an Existing Storm
Changing Storm Levels
Changing Storm Types
Forecasting Outages
Using Forecast Profiles
Working with Crew Information
Using Study Mode
Ending Storms and Exiting Storm Mode
Storm Management View Only Environment
View Only Environment User Interface
View Only Menus
Storm Management Storm Administration Environment
Administration Environment User Interface Features
Administration Menus
Storm Administration Table
Printing the Storm Administration Table
Editing Storm Records
Excludable Period Dialog
Understanding Storm Management Calculations
How Storm Management Works
Historical Averages
Simulation
Storm Management Window
Non-Storm Mode Algorithm
Non-Storm Mode Algorithm Flow Chart
Service Alert Administration
Overview
Using the Service Alert Administration Tool
General Features
User Menu
Help Menu
Contact Manager
Contact Manager Tab
Adding a Contact
Editing a Contact
Removing a Contact
Group Manager
Group Manager Tab
Adding a Group
Removing a Group
Adding a Contact to a Group
Removing a Contact from a Group
Modifying the Message Transformation File
Parameter Manager
Parameter Manager Tab
About Parameter Values
Adding a Customer Count Parameter
Adding a Specific Customer Parameter
Adding a Frequency of Outages Parameter
Adding a Storm Affecting Control Zone Parameter
Editing a Parameter
Removing a Parameter
Utility Customer Manager
Utility Customers Tab
Adding Accounts
Adding an Account to Service Alert
Searching for an Account
Searching for an Account in Service Alert
Editing an Account
Removing an Account
Adding Customer Contact Information
Searching for a Customer Contact
Searching for a Customer Contact in Service Alert
Editing Customer Contact Information
Removing Customer Contact Information
Adding Customer Contact Phone Information
Editing Customer Contact Phone Information
Removing Customer Contact Phone Information
Attribute Manager
Attributes Manager Tab
Adding Attributes
Editing a Attribute
Removing a Attribute
SCADA Extensions
Overview
Understanding SCADA Measurements
Understanding Measurement Quality Codes
Accessing and Using SCADA Features
Using the SCADA Status Window and Maintenance Tools
SCADA Status Menus and Toolbar
Understanding the SCADA Status Tree View Pane
FEP Monitor
FEP Monitor Menus and Toolbar
FEP Monitor User Interface
FEP Status
Point Monitor
Using Point Monitor Menus and Toolbar
Understanding IED Point (Filtered) Views
FEP Details
File Menu
Actions Menu
Help Menu
FEP Details Components
IED Monitor
Menus and Toolbars
Actions Menu
Help Menu
IED Summary Banner
IED Status List
IED Details and Template Details
Menus and Toolbars
Actions Menu
Help Menu
IED Common Options
IED Default Scaling Options
IED Protocol Specific Options
IED Connections and Input/Output Tab List
IED Templates List
IED Inputs
Using the Create/Update Inputs Dialog Box
Using the Analog Scaling Dialog Box
IED Outputs
Menus and Toolbars
IED Device Links
Menus and Toolbars
SCADA Audit Log
SCADA Debug Log
Understanding Template IEDs
Creating a New IED
Extending an IED
Understanding SCADA Status Actions Menu Options
Download IED Schema... Action
Export IED... Action
Import IED... Action
Understanding SCADA Options
Open IED Details...
Create IED...
Add to IED...
Understanding Jitter Protection
Using the SCADA Commissioning tool
IED View
Point View
IED Test Mode
Using the SCADA Summary
Understanding the SCADA Summary Window
Understanding the SCADA Summary Filter Pane
Viewing Data in the SCADA Summary
Viewing All SCADA Data
Viewing SCADA Data for a Selected Asset
Preventing Measurement Updates
Manual Entry and Override of SCADA Measurement Values
Adding and Modifying Comments for SCADA Status Changes
Choosing the Analog Measurements to Display in the Viewer
Hide Measurement in Viewer: Hides a measurement in the Viewer.Understanding SCADA Information in the Viewer
Enabling/Disabling SCADA Measurements in the Viewer
Choosing the SCADA Information Display
Resize Smaller: Decreases the size of the measurements. (Administration users only.)Displaying SCADA Measurements with Asset Details
Remote SCADA Operation Warnings
Using SCADA Control Tool Features
Switching Management SCADA Integration
Overview
Operating Modes
Asset Associations with Nominal and Current Network Components
Understanding Web Switching Management Windows
Overview
Web Switching Sheets
Switching Sheet Types
Switching Sheet States
Switching Sheet Window Components
Menu and Toolbar Features
Switching Sheet Tabs
Status Bar
Planned Switching
Creating a Planned Switching Sheet
Using the New Switching Sheet Window
Understanding Switching Sheet Templates
Creating a Switching Sheet Template
Understanding the Template ID Field
Creating a Switching Sheet from a Template
Switching Sheet Requests
Capabilities of the Switching Request User Type
Completing the Request Tab
Taking Ownership
Changing the Switching Sheet State
Replication
Rework
Adding and Editing Steps
Steps Tab
Assigning Crews to a Switching Sheet
Switching Sheet Step States
Adding Recorded Steps to a Switching Sheet
Adding Steps Manually
Adding Comment Steps
Resetting Operation Text
Copying and Pasting Steps
Creating Go-Back Steps
Working with Blocks
Grouping and Ungrouping Steps
Linking and Unlinking a Step to Safety Document
Step Order Execution Rules
Editing Existing Steps
Finding and Replacing an Asset in the Steps
Finding and Replacing Text in the Steps
Changing Start Date
Focusing on an Asset in a Step
Example Return to Nominal Scenarios
Reviewing a Switching Sheet in Study Mode
Replaying Steps
Implementing a Planned Switching Sheet
Scheduling a Planned Master Event
Issuing a Switching Sheet
Printing the Switching Sheet
Instructing and Completing Switching Sheet Steps
Moving a Crew
Working with Switching Sheet Versions
Step Versioning
Viewing Impacted Customers
Using the Impacted Customers Tab
Color Coding
Generating the List
Sorting Impacted Customers List
Deleting and Restoring Customers from the List
Moving Customers
Checking for Overlaps
Using the Overlaps Tab
Color Coding
Updating the Overlaps List
Viewing an Overlapping Switching Sheet
Saving and Loading View Areas
Using the View Areas Tab
Saving a Viewing Area
Loading a Saved Viewing Area
Reloading all Auto-Load Viewing Areas
Deleting a Saved Viewing Area
Viewing the Audit Log
Adding a Comment to the Audit Log
Emailing Switching Sheet Data
Automatic Emails
Adding External Documents to a Switching Sheet
Using the External Documents Tab
Adding an External Document
Removing an External Document
Saving an External Document to Another Location
Saving a Selection of External Documents to Another Location
Opening and Editing an External Document
Troubleshooting Issues with External Documents
Opening an Existing Switching Sheet
Open a Switching Sheet Window from Switching Sheet List
Open Switching Sheet using Switching Sheet Search
Copying a Switching Sheet
Deleting a Switching Sheet
Emergency Switching
Creating an Emergency Switching Sheet
Open or Create New Switching Sheet
Recording Emergency Operations
Understanding the Switching Sheet List
File Menu
Sort Menu
Actions Menu
Help Menu
Switching Sheet List Data Fields
Understanding the Switching Switch List Filter Pane
Opening Locked Documents
Stealing Locks
Event Associations
Hard Associations
Soft Associations
Rules for Grouping Event Associations
Exporting/Importing Switching Sheets
Crew Assignments
System Crews
Contractors
Working with Safety Documents
Understanding Safety Document Types
Mapping Step Types to Safety Document Types
Using Safety Documents in Switching Plans
Understanding the Safety Documents Tab
Safety Document Dialog Overview
Creating a Safety Document from a Switching Sheet
Assigning Crews to a Safety Document
Adding a Safety State Transition Step
Editing the Asset List
Executing Safety State Transition Steps
Issuing Safety Documents
Releasing Safety Documents
Delegating Control of a Network Area
Safety Document List
File Menu
Sort Menu
Actions Menu
Help Menu
Safety Document List Data Fields
Understanding the Safety Document List Filter Pane
Opening Existing Safety Documents
From the Web Workspace File Menu
From the Web Workspace Search Safety Document Dialog
Open a Safety Document from an Open Switching Sheet
Open a Safety Document from a Switching Step on the Steps Tab
Open a Safety Document from the Control Tool
Completing Safety Documents
Aborting Safety Documents
Switching Sheet Associations
Outage Correction
Correcting Outages in a Rework Sheet
Using Outage Correction Sheets
Re-Recording the Outage Restoration Sequence in Study Mode
Outage Correction Error Codes
Using the Miscellaneous Log
Displaying the Miscellaneous Log
Filtering the Log
Editing the Miscellaneous Log Steps
Viewing Global Overlaps
Web Safety
Understanding the Stand Alone Safety Document Window
Safety Document Fields
Creating New Stand Alone Safety Documents
Creating a Safety Document from the Web Workspace
Creating a New Safety Document from the Control Tool
Using Stand Alone Safety Documents
Record Tag Operations
Record Ground Operations
Remove an Asset from a Safety Document
Issuing, Releasing, and Completing a Safety Document
Loading a Safety Document
Deleting a Safety Document
Copying a Safety Document
Create a Safety Document in Study Mode
Associate an Existing Place Tag Action to a Safety Document
Model Management
Overview
Using the Model Management Window
Menu and Toolbar Options
File Menu
Actions Menu
User Menu
Preferences Menu
Help Menu
Pending Map Section
Pending Map Actions
Patches Section
Status Bar
Model Management Actions
Displaying Map History
Displaying the Preprocessor Log
Building Maps
Rebuilding a Patch
Displaying the Patch Build Log
Displaying the Patch Build Report
Enabling and Disabling Model Building
Configuration Assistant
Getting Started with the Configuration Assistant
Understanding Configuration Assistant Menus and Toolbar
Using the User Administration Tab
Understanding the Current Users Pane
Adding a User
Editing a User
Removing a User
Saving Exported User Configuration
Understanding the User Type Memberships Pane
Product User Type Matrix
Changing User Type Memberships
Reorder Current User Types
Understanding the User Log Pane
Resetting a User Login
Using the User Permissions Tab
Understanding the Permissions (FlexOps & OMA) Pane
Adding Permissions
Editing Permissions
Removing Permissions
Using the Flex User Administration Tab
Understanding User Type Permissions Pane
Adding User Types and Assigning Permissions
Removing Permissions from a User Type
Controlling Permissions at a User Level
Using the Mobile User Administration Tab
Understanding the Mobile Users Pane
Mobile User Type Memberships
Current Keys
Permission Sets
Changing Permission Sets
Using the Event Management Rules Tab
Event Management Rules Components
Rule Categories Pane
Currently Configured Rules Pane
Documentation Pane
Working with Rules
Add a Rule to the Configuration
Edit a Rule in the Configuration
Remove a Rule from the Configuration
Export Configuration
Using the Event Details Options Tab
Event Details Options Pane
Adding an Options Pane Submenu
Adding an Option
Removing an Option
Editing an Option
Saving Exported Event Details Configuration
Reordering Options
Using the Schematica Options Tab
Understanding the Schematica Options Pane Components
Working with Schematica Options Tab Functions
Creating a Copy Pack
Adding an Option
Removing an Option
Editing an Option
Running the Schematic Generation
Saving Exported Schematica Options Configuration
Using the State Transitions Tab
Viewing State Transitions
Example: New Damage Assessments State Transitions
Using the Default Restoration Times Tab
Asset/Zone Default Restoration Times Pane
Columns
Buttons
Row Highlighting
Adding an Asset/Zone-Based Default Restoration Time
Modifying an Asset/Zone-Based Default Restoration Time
Deleting an Asset/Zone-Based Default Restoration Time
Saving an Exported Default Restoration Time Configuration
Using the Limit Configuration Tab
Understanding the Limit Groups Table
Buttons
Understanding the Limit Sets Table
Buttons
Understanding the Limit Bands Table
Buttons
Using the Alarm Configuration Tab
Understanding the Behavior Tab
Alarm Behavior Table
Understanding the Add / Edit Alarm Definition Dialog Box
Understanding the Active Alarms List
Understanding the Mapping Tab
Buttons
Using the Add / Edit Alarm Mapping Dialog Box
Understanding the Priorities Tab
Buttons
Using the Add / Edit Alarm Priority Dialog Box
Understanding the Classes Tab
Using the Add / Edit Alarm Classes Dialog Box
Understanding the Categories Tab
Using the Add / Edit Alarm Categories Dialog Box
Understanding the Attributes Tab
Using the Add / Edit Attributes Dialog Box
Using the Customer Administration Tab
Menus and Toolbar
Actions Menu
Options Menu
Setting Debug
Columns
Manual Debug Entry
Using the Customer Administration Weighted Priority Editor
Editing a Customer Weighted Priority
Resetting Weighted Priority
Accessibility Features
Understanding NMS Keyboard Navigation Methods
Link Selection
Using NMS with a Screen Reader
High Contrast
Screen Scaling
Acronyms
Event Status and Event Type Codes
Event Status Codes
Event Type Codes
Color Coding
Crew Status
Event Status
Feeder Automation Status
Callback Status
Pipe Symbology
Tool to User Type Matrix
Web Workspace
Storm Management
WWSortDialog
WWFilterDialog
WWEditFilterDialog
WWEman
WWChangeTimeZoneDialog
WWManageWorkspaceLayouts
WWConditionalFormatting
WWAuthorityWindow
WWCreateEvent
WWWorkAgenda
WWLoadcompleteevent
WWLoadcompleteEventrange
WWViewerWindow
WWViewerDeviceInfo
WWViewerDeviceSCADA
WWSearchDialog
WWSelectdevice
WWHideDisplayDialog
WWTraceDialog
TraceResultsDialog
CommissioningTool
AssessmentTool
SaveCaseMgmt
WWControlTool
WWConditionDataDialog
WWCreateEditableTags
WWLookAheadWindow
WWLADropCountsTab
WWLAPickupCountsTab
WWLAViewConditionsTab
WWLAViewAbnormalTab
WWLAViewCriticalTab
WWManageDocs
WWConditionSummary
WWConditionEditDialog
WWAlarmsList
WWAbnormalDevicesList
WWAlarmHistoryList
WTUserLog
WTEventDetails
WTEDJobActionsTab
WTEDCompletionActionsTab
WTEDEquipmentFailureTab
WTTroubleInfoWindow
WTCallInfo
WWUngroupdialog
EditClues
WTMoveCustomers
DamageAssessmentsList
WTEventLog
WebSwitching_EventDetailsSteps
WTAttachments
WTEventDetailsDlg
WTConfirmOutages
WWREferral
WTGroupEvents
WWAssociateEvent
WWUnassociateDialog
DamageAssessment
WWSelectCrewdialog
WWSelectDamageLocation
WWAddLinkdialog
WWIgnoredERT
WWGlobalERT
WTCrewList
WWSetCrewOnShiftDialog
WWSetCrewOffShiftDialog
WWUpdateCrewAvailability
Gantt
WTCrewMakeup
WTCrewInfo
WWUpdateAssignmentDuration
WebCallEntryWindow
WWIntersectionSearchDialog
WCECallHistoryWindow
WCEEventHistoryWindow
WWFuzzyCallDialog
WCEOutagesSummary
WebCallbacksWindow
AssignCallbacksWindow
ViewMyCallbackWindow
PerformCallbackWindow
PerformNextCallbackWindow
StormMgtFOE
WWERTOverride
WWForecastProfiles
WWImportCrew
WWCalculateCrews
WWDefineStorm
WWEndStorm
StormMgtVOE
StormMgtSAE
WWExcludableStormPeriod
ServiceAlertWindow
SAContactManagerTab
SAGroupManagerTab
SAParameterManagerTab
SAUtilityCustomersTab
SAAttributesManagerTab
ScadaFepMonitor
ScadaPointMonitor
ScadaRtuTemplates
ScadaRtuMonitor
ScadaRtuDetails
ScadaSelectTemplate
ScadaInputPoint
ScadaInputFilter
ScadaOutputPoint
ScadaAuditLog
ScadaDebugLog
WWSCADASummary
WWManualEntryandoveride
WWEnableComments
WWControlComments
WSSwitchingEntryWindow
WSSwitchingMgtWindow
WebSwitching_UpdateStepDetails
WSNewWindow
WebSwitching_TemplateID
WSRequestTab
WebSwitching_ReplicateSwitchingSheets
WebSwitching_AutomaticallyCompleteReworkedSteps
WSStepsTab
WebSwitching_MoveStepToMiscLog
WSUpdateInstructDate
WWAddEventAssociation
SwmanSelectCrewDialog
WWSelectOperation
WWAddCustomBlock
WWRenameCustomBlock
WebSwitching_CuttingEventSteps
WebSwitching_LinkSafetyFromStep
WWFindandReplaceDevice
WWFindandReplaceText
WWChangeStartDate
WSConfirmComplete
WSImpactedCustomersTab
WSMoveCustomers
WSOverlapsTab
WSViewAreasTab
WSTrackingAuditLogTab
WSExternalDocumentsTab
WSSearchWindow
WWDeviceSheets
WSCopyWindow
WSOpenWindow
WWLockedObjectsDialog
WWStealLockedObjects
WSSafetyDocumentsTab
WSSafetyDocumentDialog
SelectDevicePhases
WebSafety_LinkStepToDoc
WebSafety_CreateDocFromStep
SafetyDocumentSelectCrewDialog
WWSafetyStateTransitionFailed
WWSafetyAddDevice
WWSafetyExecute
WSOpenSafetyWindow
WSSearchSafetyWindow
WWDeviceSafetyDocs
WSAssocSafetyDocument
WSWReworkSteps
WSMiscLog
WSGlobalOverlaps
WSStandAloneSafetyDocument
WSNewSafetyWindow
WebSafetyCopyDocument
ModelManagementWindow
WWBuildMaps
WWPatchBuildlog
WWPatchBuildReport
CAWindow
CAUserAdminTab
CAMobileUserAdminTab
CASRSRulesTab
CAEventDetailsTab
CASchematicaTab
CADMSAppAdminTab
CAFeederManagementTab
CAStateTransitionsTab
CADefaultERT
CALimitConfigurationTab
CAAlarmConfigurationTab
CACustomerAdminTab
SetDebugDialog
