Conditional Formatting Dialog
The Conditional Formatting dialog box allows you to add and manage the conditional formatting rules associated with a table:
The fields and buttons are described below:
• List of Rules: Displays a list of the formatting rules applied to the table. Each rule displays:
• Rule Name: The name of the rule.
• Row: A check box that indicates if the rule is configured to format the row (selected) or just the cell (deselected).
• Conditions: The conditions that must be met if the formatting is to be applied. Defining the conditions is equivalent to creating a filter; see Creating and Editing Filters Using the Edit Filter Dialog Box on page 1-11 for more information.
• Column: The name of the column(s) to highlight with the formatting.
• Format: The formatting associated with the rule
Note that the position of the rule in the list determines its precedence. See Understanding Conditional Formatting Precedence Rules on page 2-21 for details.
• Actions that can be performed on each rule:
• Move Up: Moves the selected rule up the list.
• Move Down: Moves the selected rule down the list.
• Edit: Displays the Edit Rule Dialog, which allows you to specify the formatting rule. (You can also double‑click the rule to open it for editing.)
• Remove: Removes the selected rule.
• Duplicate: Creates a copy of the rule and allows you to edit it.
• Insert: Inserts a new rule above the selected rule and allows you to edit it.
• Add: appends a new rule to the bottom of the list and allows you to edit it.
• Actions that can be applied to the dialog:
• Help…: Displays Help for the Conditional Formatting dialog
• OK: Applies any changes and closes the dialog.
• Apply: Applies any changes but leaves the dialog open.
• Cancel: Closes the dialog without applying any changes.
