Opening the Save Case Management Tool
If you are creating a new save case, you would perform device operations prior to opening the Save Case Management tool. Conversely, if you want to start a study session based on an existing save case, you would not want to perform any device operations because the model will be reset to the topology as it existed when the save case was created.
To open the Save Case Management tool, do the following:
1. Start a Study Session. See Real-Time and Study Mode on page 2-73 for more information.
2. From the Viewer's Options menu, select Study Mode, and then select Save Case Management....
Note: This option is also available from the Web Switching Steps tab's Reset context menu.
Save Case Management Tool Menus and Toolbar Options
File Menu
Option
Description
Toolbar Button
Print
Displays the Print Preview dialog box, which allows you print the Save Cases table.
Exit
Closes the Save Case Management tool.
Actions Menu
Option
Description
Toolbar Button
Save Case Details...
Displays the Save Case Details dialog box with the save case details for the selected row.
Reset
Real-Time: resets the current study session to the real-time model.
Nominal: resets the current study session to the nominal model.
Selected Save Case: resets the current study session to the save case for the selected row.
Save...
Opens the Save Case Details dialog box with the steps from the current study session.
Delete...
Displays a confirmation dialog box before deleting the selected save case.
Help Menu
Option
Description
Toolbar Button
Save Case Help
Opens the Oracle Utilities Network Management System's online help content for the Save Case Management tool.
Save Case Management Tool Data Fields
The Save Case Management tool's table contains the following information:
The Save Case Name field displays the name of the save case.
• The Description field displays a description added to the save case.
• The User field displays the name of the user who created the save case.
• The Created Date field displays the date when the save case was saved.
• The Base field displays the model that the save case was created against.
