Using the Event Log Tab
The Event Log tab displays a table with all actions taken for the event. To display the Event Log for a particular event, select a row in the Work Agenda list and select Event Log... from the Actions menu.
The table displays the following information:
• The Date/Time field displays the date/time of the log entry.
• The User field displays the user that initiated the action.
• The Event field displays the identifier of the original event for which the log entry was generated. Note that, due to grouping activities, the original event may no longer exist.
• The Text field displays a description of the log entry.
The Event Log may be exported using the Event Details File menu’s Export Table... option, which is visible on the Event Log and certain other tabs having table data that can be exported.
