Help Menu
Menu Option
Description
Web Callbacks Help
Launches the online help system and loads the Web Callbacks content.
Email Log Files...
Gathers the environment’'s log files and attaches them to a new email message using your default email client. The log files can then be sent to your support team or contact for further analysis.
Set Debug...
Launches the Set Debug dialog box allowing you to set debug on or off within your current environment. This is used for debugging and analysis purposes. See Setting Debug on page 24-67 for more information.
About Web Callbacks
Opens a window with environment and software information.
Header
Beneath the Web Callbacks Toolbar is the header section. This section contains information regarding who is logged in to the application.
• The User Name field displays your Web Callbacks login user name. This field is not editable.
Callbacks Table
The Web Callbacks table contains a detailed list of each resolved event that still has callbacks remaining. These rows are color-coded by the status of the callback (not started versus in progress).
The Callbacks Table displays the following columns:
• The Event # column contains the unique number of the event.
• The # Callbacks column contains the number of callbacks for the event.
• The # Pri column contains the number of callbacks from priority calls for the event.
• The % Comp column contains the percentage of callbacks completed for the event.
• The # Rem column contains the number of callbacks remaining for the event.
• The # Asn column contains the number of remaining callbacks for the event that have been assigned.
• The Start Date column contains the reported start date and time of the event.
• The Restore Date column contains the date and time the event was restored.
• The Device column contains the name of the device associated with the event.
• The Status column contains the status of callbacks for the event:
• In Progress - Some callbacks for the event have been completed.
• Not Started - Some callbacks for the event may have been assigned, but no callbacks are completed.
• The Substation column contains the name of the substation for the device associated with the event.
• The Zone column contains the name of the branch office where the event occurred.
• The # Users column contains the number of users with assigned callbacks for the event.
